Results 1 to 3 of 3
Thread: Extractors and turbo on N/A td4.2
    Oct 2021
    Hey guys, I’m only 16 and bought myself a td42 gq and currently doing it up, it’s a N/A and has extractors on it, I was wondering if I can put a turbo on it without taking the extractors off, and just have both, or do I have to have one and not the other or if I can have both but need a custom manifold, any help will do
    Cheers, josh
    Legendary happygu's Avatar
    You can't have both - either extractors or the turbo with turbo manifold.
    Check to make sure that you are allowed to run a turbo on your provisional licence before you do anything.
    If I was you, I would run it as is for a while, and get used to the vehicle as you might find with a bit of running around that there are other areas that need money/attention. You might have hit the gold mine, and have plenty of money, but i do remember it running out quickly once you start running around.
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    Inspiration: https://www.youtube.com/watch?v=N-X8d_WRovw
    Also look up "TorqAmp 48v electric compressor turbo"
    2008 CRD Auto Wagon
