Results 1 to 3 of 3
Thread: Electric windows GU patrol
    Dec 2020
    Hi I cannot get the motor on the LHS front window to go up, it will go down but not up, any ideas where to start.
    I was going to remove the motor and reg and plug it into the rear passenger to see if it’s the motor.
    Feb 2011
    Shed
    45 Post(s)
    Could it be a dirty contact on the switch?
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    It is almost always the switch. They can be taken apart and cleaned - but it is an ongoing Patrol problem. Sooner or later it will happen - especially to windows that are not often used. If you continue to move the switch up and down rapidly for a while it sometimes works again. I have often thought about getting a gold plating kit and plating the contacts inside the switch.
