Results 1 to 1 of 1
Thread: model facts 1985
    Jul 2010
    Waterford West Qld
    model facts 1985
    1985 NISSAN PATROL (4x4)
    2Door HARDTOP 4 SEATS, 4WD, DIESEL, 5 SP MANUAL 4x4
    » Release Date: Jan-1984
    » Max. Torque: 215Nm
    » Max. Power: 70kW
    » Power to Weight Ratio: 27.07:1 kW/kg
    » Fuel Type: DIESEL
    » Dimensions: L(4070mm), H(1880mm), W(1690mm)
    » Towing Capacity: Brake(2400kg), Unbrake(750kg)
    » Turning Circle: 11.8m
    4Door WAGON 6 SEATS, 4WD, DIESEL TURBO, 5 SP MANUAL 4x4
    » Max. Torque: 255Nm
    » Max. Power: 81kW
    » Power to Weight Ratio: 23.95:1 kW/kg
    » Fuel Type: DIESEL
    » Dimensions: L(4690mm), H(1850mm), W(1690mm)
    » Turning Circle: 14.2m
    P/UP 3 SEATS, 4WD, DIESEL, 5 SP MANUAL 4x4
    » Max. Power: 70kW
    » Power to Weight Ratio: 24.21:1 kW/kg
    » Fuel Type: DIESEL
    » Dimensions: L(4785mm), H(1895mm), W(1690mm)
    2Door HARDTOP 2 SEATS, 4WD, CARB, 4 SP MANUAL 4X4
    » Max. Torque: 201Nm
    » Max. Power: 88kW
    » Power to Weight Ratio: 18.92:1 kW/kg
    » Fuel Type: LEADED PETROL
    2Door HARDTOP 4 SEATS, 4WD, CARB, 4 SP MANUAL 4X4
    » Release Date: Jan-1980
    » Max. Power: 88kW
    » Power to Weight Ratio: 18.12:1 kW/kg
    » Towing Capacity: Brake(2100kg), Unbrake(750kg)
    » Turning Circle: 11m
    P/UP 3 SEATS, 4WD, CARB, 5 SP MANUAL 4x4
    » Max. Torque: 270Nm
    » Max. Power: 85kW
    » Power to Weight Ratio: 20.18:1 kW/kg
    4Door WAGON 6 SEATS, 4WD, CARB, 5 SP MANUAL 4x4
    » Max. Power: 88kW
    » Power to Weight Ratio: 20:1 kW/kg
    P/UP 3 SEATS, 4WD, DIESEL TURBO, 5 SP MANUAL 4x4
    » Max. Power: 81kW
    » Power to Weight Ratio: 22.04:1 kW/kg
    » Fuel Type: DIESEL
    1985 NISSAN PATROL DELUXE
    4Door WAGON 7 SEATS, 4WD, CARB, 4 SP MANUAL 4X4
    » Release Date: Jan-1981
    » Max. Power: 88kW
    » Power to Weight Ratio: 19.2:1 kW/kg
    » Dimensions: L(4690mm), H(1845mm), W(1690mm)
    » Turning Circle: 13.4m
    4Door WAGON 7 SEATS, 4WD, DIESEL TURBO, 5 SP MANUAL 4x4
    » Max. Power: 81kW
    » Power to Weight Ratio: 25.19:1 kW/kg
    » Fuel Type: DIESEL
    1985 NISSAN PATROL GL
    » Release Date: Jan-1985
    » Max. Power: 70kW
    » Fuel Type: DIESEL
    2Door HARDTOP 4 SEATS, 4WD, CARB, 5 SP MANUAL 4x4
    » Max. Power: 88kW
    » Power to Weight Ratio: 19.6:1 kW/kg
  2. The Following 2 Users Say Thank You to Finly Owner For This Useful Post:
    AndyExy (21st May 2012), Crankshaft (30th May 2012)
