29th July 2011, 10:28 PM
model facts 1984
1984 NISSAN PATROL (4x4)
2Door HARDTOP 2 SEATS, 4WD, CARB, 4 SP MANUAL 4X4
» Release Date: Jan-1984
» Max. Torque: 201Nm
» Max. Power: 88kW
» Power to Weight Ratio: 18.92:1 kW/kg
» Fuel Type: LEADED PETROL
» Dimensions: L(4070mm), H(1880mm), W(1690mm)
» Towing Capacity: Brake(2400kg), Unbrake(750kg)
» Turning Circle: 11.8m
P/UP 3 SEATS, 4WD, DIESEL TURBO, 5 SP MANUAL 4x4
» Max. Torque: 255Nm
» Max. Power: 81kW
» Power to Weight Ratio: 22.04:1 kW/kg
» Fuel Type: DIESEL
» Dimensions: L(4785mm), H(1895mm), W(1690mm)
» Turning Circle: 14.2m
4Door WAGON 6 SEATS, 4WD, CARB, 5 SP MANUAL 4x4
» Max. Power: 88kW
» Power to Weight Ratio: 20:1 kW/kg
» Dimensions: L(4690mm), H(1850mm), W(1690mm)
2Door HARDTOP 4 SEATS, 4WD, DIESEL, 5 SP MANUAL 4x4
» Max. Torque: 215Nm
» Max. Power: 70kW
» Power to Weight Ratio: 27.07:1 kW/kg
» Fuel Type: DIESEL
2Door HARDTOP 4 SEATS, 4WD, CARB, 4 SP MANUAL 4X4
» Release Date: Jan-1980
» Max. Power: 88kW
» Power to Weight Ratio: 18.12:1 kW/kg
» Towing Capacity: Brake(2100kg), Unbrake(750kg)
» Turning Circle: 11m
P/UP 3 SEATS, 4WD, DIESEL, 5 SP MANUAL 4x4
» Max. Power: 70kW
» Power to Weight Ratio: 24.21:1 kW/kg
» Fuel Type: DIESEL
4Door WAGON 6 SEATS, 4WD, DIESEL TURBO, 5 SP MANUAL 4x4
» Max. Power: 81kW
» Power to Weight Ratio: 23.95:1 kW/kg
» Fuel Type: DIESEL
P/UP 3 SEATS, 4WD, CARB, 5 SP MANUAL 4x4
» Max. Torque: 270Nm
» Max. Power: 85kW
» Power to Weight Ratio: 20.18:1 kW/kg
1984 NISSAN PATROL DELUXE
4Door WAGON 7 SEATS, 4WD, DIESEL TURBO, 5 SP MANUAL 4x4
» Max. Power: 81kW
» Power to Weight Ratio: 25.19:1 kW/kg
» Fuel Type: DIESEL
» Dimensions: L(4690mm), H(1845mm), W(1690mm)
4Door WAGON 7 SEATS, 4WD, CARB, 3 SP AUTOMATIC 4X4
» Release Date: Jan-1982
» Max. Power: 88kW
» Power to Weight Ratio: 19.2:1 kW/kg
» Turning Circle: 13.4m
4Door WAGON 7 SEATS, 4WD, CARB, 4 SP MANUAL 4X4
» Release Date: Jan-1981
» Max. Power: 88kW
29th July 2011 10:28 PM
