29th July 2011, 10:16 PM
model facts 1981
1981 NISSAN PATROL (4x4)
P/UP 3 SEATS, 4WD, DIESEL, 4 SP MANUAL 4X4
» Release Date: Jan-1980
» Max. Torque: 280Nm
» Max. Power: 89kW
» Power to Weight Ratio: 18.99:1 kW/kg
» Fuel Type: DIESEL
» Dimensions: L(4785mm), H(1835mm), W(1690mm)
» Turning Circle: 13.4m
2Door HARDTOP 4 SEATS, 4WD, CARB, 4 SP MANUAL 4X4
» Max. Torque: 201Nm
» Max. Power: 88kW
» Power to Weight Ratio: 18.12:1 kW/kg
» Fuel Type: LEADED PETROL
» Dimensions: L(4070mm), H(1880mm), W(1690mm)
» Towing Capacity: Brake(2100kg), Unbrake(750kg)
» Turning Circle: 11m
2Door HARDTOP 4 SEATS, 4WD, DIESEL, 4 SP MANUAL 4X4
» Max. Torque: 215Nm
» Max. Power: 70kW
» Power to Weight Ratio: 24.79:1 kW/kg
» Fuel Type: DIESEL
» Towing Capacity: Brake(1700kg), Unbrake(750kg)
» Max. Power: 70kW
» Fuel Type: DIESEL
1981 NISSAN PATROL DELUXE
4Door WAGON 7 SEATS, 4WD, DIESEL, 4 SP MANUAL 4X4
» Max. Power: 70kW
» Power to Weight Ratio: 26.07:1 kW/kg
» Fuel Type: DIESEL
» Dimensions: L(4690mm), H(1845mm), W(1690mm)
4Door WAGON 7 SEATS, 4WD, CARB, 4 SP MANUAL 4X4
» Release Date: Jan-1981
» Max. Power: 88kW
» Power to Weight Ratio: 19.2:1 kW/kg
The Following User Says Thank You to Finly Owner For This Useful Post:
29th July 2011 10:16 PM
29th July 2011, 10:31 PM
What was the diesel engine that had 89kw and 280Nm?
Tony
29th July 2011, 10:41 PM
YNOT
Tony
4L diesel
Tim
29th July 2011, 10:44 PM
Finly Owner
4L diesel
Tim
You don't see many of them, more power and torque than the SD33T.
Tony
29th July 2011, 11:09 PM
YNOT
Tony
Scary ain't it?
Tim
1st August 2011, 10:23 AM
4L diesel ????
SD33,L28,P40 (4L petrol)
