Results 1 to 1 of 1
Thread: model facts 1980
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    model facts 1980
    1980 NISSAN PATROL (4x4)
    P/UP 3 SEATS, 4WD, DIESEL, 4 SP MANUAL 4X4
    » Release Date: Jan-1980
    » Max. Torque: 280Nm
    » Max. Power: 89kW
    » Power to Weight Ratio: 18.99:1 kW/kg
    » Fuel Type: DIESEL
    » Dimensions: L(4785mm), H(1835mm), W(1690mm)
    » Turning Circle: 13.4m
    » Max. Torque: 215Nm
    » Max. Power: 70kW
    » Power to Weight Ratio: 24.79:1 kW/kg
    » Fuel Type: DIESEL
    » Towing Capacity: Brake(1700kg), Unbrake(750kg)
    2Door HARDTOP 4 SEATS, 4WD, CARB, 4 SP MANUAL 4X4
    » Max. Torque: 201Nm
    » Max. Power: 88kW
    » Power to Weight Ratio: 18.12:1 kW/kg
    » Fuel Type: LEADED PETROL
    » Dimensions: L(4070mm), H(1880mm), W(1690mm)
    » Towing Capacity: Brake(2100kg), Unbrake(750kg)
    » Turning Circle: 11m
    2Door HARDTOP 4 SEATS, 4WD, DIESEL, 4 SP MANUAL 4X4
    » Max. Power: 70kW
    » Fuel Type: DIESEL
    1980 NISSAN PATROL DELUXE
    4Door WAGON 7 SEATS, 4WD, DIESEL, 4 SP MANUAL 4X4
    » Max. Power: 70kW
    » Power to Weight Ratio: 26.07:1 kW/kg
    » Fuel Type: DIESEL
    » Dimensions: L(4690mm), H(1845mm), W(1690mm)
  2. The Following User Says Thank You to Finly Owner For This Useful Post:
    YNOT (29th July 2011)
