4th September 2011, 05:50 PM
taslucas
Hi guys, I just read the thread and so went outside to make sure what mine was. Thought it was an MQ, headlights are MQ (round), Shackles are MQ (straight) but the rego says 1987 for the year of manufacture? Maybe someone did the dodgy on the rego once? (its only off road now anyway)
Also; I see a lot more MQs (round headlights) than MKs. Like 1 MK to every 5 MQs. Were more MQs sold in Aus? Maybe tassie is just that little bit more behind? lol
1987 MQ , not likely
Theres something sus there
You can put straight shackles on an MK
The shackles arent vertical but a tad on an angle,Ive an MK with that done
I removed the snake racing shackles and had no other shackles to fit except MQ straight ones, so they do fit
As for tassie being a little more behind ???
Not goin there
The Following User Says Thank You to MQ MAD For This Useful Post:
Finly Owner (5th September 2011)
4th September 2011 05:50 PM
10th September 2011, 12:02 AM
MQ MAD
Not goin there
Yeah im fairly sure that someone did the dodgy on the rego. I got the bus cheap and only use it off road now (i know its definately not stolen so thats all good). I thinks ive figured out that is a 1983.
As for tassie being a bit behind, well i gave you a free shot, you shoiuld have taken it! lol
Thanks for the info
30th September 2011, 05:17 PM
i got both a mq and mk and the front shackles are both different its something to do with the eye on the spring is bigger on the mk then the mq ill find out when i swap the front diff over and find out where this oil leek is comming from
3rd May 2012, 08:03 PM
My Mq shorties -- aren't.. They are in fact MK's interesting that the VIN starts with KM?? both square headlights and one with the bent shackles. The other has different springs and the bushes are mangled as aresult of being sandwiched with straight shackles.
I am about to swap clutches so I hope there are no other differences. LOL
3rd May 2012, 11:41 PM
When I replaced my front bush'son my Mk the metal sleaves had weld them selfs to thepins. I had to cut the wins using a hack saw blade.
I got replacement pins & bushes. They wherre the onle vendor I could find that listed parts for the MQ & MK.
Dont forget the MK came with 5 & 4 speed box's and a SD33TD
6th May 2012, 12:30 AM
Suspension and steering were still not upgraded much until the Late 1985 models. That is when they fitted the best suspension (extra leafs) and improved the steering. Late 85/86 on have the best factory fitted suspension, 7 leaf from memory without climbing under and counting.
Cheers Ric
14th May 2012, 06:57 PM
#17
http://s1100.photobucket.com/albums/...ussie_male1au/
Here is my project (wife hates that word), on the left is the MK, the one on the right the MQ. Body of MK is going to be transplanted to the chassis of the MQ..Obviously I've thought this was going to be too easy so have added in the difficulty level by making the MK a diesel and the MQ a petrol...still too easy..well..how about the MK being 24volt and the MQ 12volt. Problem with alcohol is these ideas sound good at the time LOL,
15th May 2012, 03:04 PM
#18
I have a 85 MK that we race, it has the angle shackles on it, just replaced them with shorter units as the long travel ones i had i kept breaking, we even ended up cracking the chassis around where they mount, the shorter ones now are much stronger and have more confindence in the front end.
17th May 2012, 12:47 PM
#19
aussiemale
What are you doin exactly ???
Maybe ive had to much alcopops when reading this ???
you can do just about anything with these ol rigs,goin diesel to petrol or the other way
The wiring needs to be changed, fairly simple front harness, the engine mounts on the chassis are different
