20th September 2021, 12:45 PM
'09 Brake Bleeding
Hey all,
Was planning on doing my brake fluid this afternoon however unsure whether there is a load adjustment valve or something else of this sort on a 2009 GU? Couldn't see anything that looked likely, but wanted to double check.
20th September 2021 12:45 PM
20th September 2021, 03:00 PM
Yep - it's above the rear diff and most people (and mechanics) make the mistake of not bleeding it. It tends to collect moisture and gunk when not bled and then fail causing all sorts of brake issues. There are a number of threads here about the LPV.
you will have a bias valve in the rear. tucked up high above the diff centre.
20th September 2021, 03:19 PM
Thanks gents, does the bias valve get bled first and just the same as any other nipple?
20th September 2021, 07:52 PM
Mcflurry
Do the rear wheels first then bias valve, then the fronts.
Mcflurry (20th September 2021)
20th September 2021, 08:19 PM
mudski
Legend thanks mate
Sent from my Pixel 2 XL using Tapatalk
21st September 2021, 07:10 AM
I think the manual says do the LSV first (I believe later GUs don't have one) then left rear, right rear then front. Disconnect battery if you have ABS.
The LSV, if it's there, is the furthest point from the master cylinder.
John
The Following User Says Thank You to jff45 For This Useful Post:
geoffayres (21st September 2021)
21st September 2021, 08:36 AM
jff45
Yes you are right John. Valve first. The left and right rear. and I did not know the later models didn't have them. thats strange...
21st September 2021, 09:27 AM
I think the later GUs had the ABS/VDC so the load sensing valve became unnecessary.
John
mudski (21st September 2021)
21st September 2021, 10:12 AM
Mine has ABS and also the valve. The bleed nipple on the valve is not easy to get to if you don't have a hoist - but not impossible. When you bleed it look at the colour of the fluid that comes out. Usually if the valve has never been bled (a common issue) the fuid will be a dark colour.
