Results 1 to 8 of 8
Thread: electric window switch
    Expert jman69's Avatar
    S.A.
    Hi there, can anyone tell me how to get to the drivers side window switches? The toggle switch for the left rear seems to be faulty. Thanks in advance.
    Hi mate. GQ or GU?
    S.A.
    It's a G.U. 1998
    You might need to unscrew the arm rest and slide it backwards to take the top off. There is a screw in the bottom of the grab
    S.A.
    Thanks mate, i'll give it a go.
    S.A.
    Ok, just had a look. I undid the screw but it would not move. So i tried to pull up the pad that you rest your elbow on, it came off. then the plastic moulding that houses the switch lifted out easily. So if anyone else needs to do this, that's how. Easy. Thanks mudrunner you put me on the right track.
  8. The Following User Says Thank You to jman69 For This Useful Post:
    MudRunnerTD (19th September 2021)
    S.A.
    just incase someone else has a faulty switch like i did, before you buy another one try a spray of ''servisol'' electrical clean and lube. Avaliable from jcar.
  10. #8
    Sep 2021
    file ///sdcard/
