Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Lost pressure in clutch pedal
    330 Post(s)
    I reckon it is a Vac issue. So it feels Normal with some feedback most of the time and super lite zero feedback pedal that lifts back off the floor though by itself? Not a zero feedback pedal that stays on the floor?
    If it lifts back automatically And regardless of the pedal feel the Clutch functions? Then I think it is Vacuum related and not a system fault. Does it ever happen at first gear at a stand still and the clutch still works? If so then I would say 100% Not a Master or Slave fault. Zero Vacuum would make the peddle like a Brick and nearlly impossible to push down (try pushing the clutch in with the engine off, that is zero vacuum) I think it is important to determine if it happens while stationary at the lights. It is easy to change gears without a clutch at all through the rev range but NOT while stationary.
    Aug 2021
    OK here I go again, I've tried replying to this thread multiple times but my reply isn't showing up.
    I replaced the master and slave cylinder and still got the same results.
    I ordered a handheld bleed pump and bled the lines using the pump from each bleed nipple(passenger side bonnet and on the slave cylinder) starting with the slave.
    I'd do this once until I couldn't see anymore air coming out, pump the pedal and until I had good pressure, left it for 15 mins and if the pedal went soft after 15 mins I'd do the process again. Took around 5 tries until the pedal stopped going soft.
    Been going almost a year now with no issues.
  4. The Following 3 Users Say Thank You to JDM22 For This Useful Post:
    MB (1st August 2022), MudRunnerTD (31st July 2022), mudski (1st August 2022)
  5. #13
    330 Post(s)
    Thanks for the follow-up mate. It helps others when searching for answers when the thread is finalised. Cheers.
