Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Lost pressure in clutch pedal
    Aug 2021
    Hi all,
    I have a 96 gq Td42 wagon. The clutch has been going on it. Last week on the way home from work I lost clutch pedal pressure. I could get it back by pumping the pedal a few times but pressure would go again after a few seconds. I dropped it into a clutch specialist, had the clutch replaced and after picking up it on my drive home the pressure went again.
    Gear changes seems fine(goes into gear easy, no grinding etc) with or without pedal pressure.
    I've checked the slave cylinder, no visible leaks. Had a friend press the pedal while I was under the car and slave is operating.
    Can't find any visible leaks around the master cylinder (fluid level may have potetlntially dropped a little, its under the max mark but I'm an idiot and didn't check it until i had problems) or anywhere on the lines.
    So I'll be honest, I'm pretty mechanically inept but my thoughts is if it was the slave i would of expected a leak underneath the car and the reservoir empty. If it was the booster I thought I would be be having the opposite syptoms (clutch much harder to press?) which leads me to the master. But I'm at a loss because the clutch seems to be engaging and gear changes are fine even with no pressure.
    Im going to order a new slave and master today and have a go at fitting them myself.
    If it fixes the issue will update this post.
    In the meantine, anyone had any similar issues?or even if my line of thinking somewhat makes sense? I'm at a total loss.
    Thanks, J
    The master farter
    mudski's Avatar
    461 Post(s)
    The clutch fork does bend and break on the odd occasion in Patrols. Also the pivot ball the fork rests on snaps off. Failing those, you probably have air in the system. Or the hose has gone soft and bellowing out when the clutch is depressed.
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    The clutch "specialist" should have dealt with all the issues when replacing the clutch.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    MudRunnerTD (31st July 2022)
  6. #4
    The master farter
    mudski's Avatar
    461 Post(s)
    In an ideal world...
  7. #5
    SW Vic.
    80 Post(s)
    Not really. If he replaced the most expensive piece of the system ( clutch) because of the problem, and the problem is still there then the 'Specialist' should fix it.
    Sounds as if he was out for easy money.
  8. #6
    Patrol Guru BrazilianY60's Avatar
    Apr 2021
    Brazil
    2 Post(s)
    Quote Originally Posted by JDM22 View Post
    To me, this indicates Master Cylinder.
  9. #7
    The master farter
    mudski's Avatar
    461 Post(s)
    Sounds like that to me aswell.
    Should is the key word there Craig. People that work in all trades should do many things, but as I've experienced over the last 18 months, they never do. You always have to finish the work yourself. Trust no one.
    As for the OP's issue. I think maybe just air in the system.
  10. #8
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    2 Post(s)
    I'd be looking at master cyl.
    Internal seal is probably gone allowing fluid to leak back into reservoir with no external leaks
  11. #9
    Aug 2021
    Thanks for the replies everyone. In fairness to the specialist he asvised me he was booked out for a month. I explained my situation and he booked me in for the following week.
    So I tried bleeding went through 2 bottles of fluid and still the same(although searching the forums the GQs are apprently notorious for being a ***** to bleed) Slave and master cylinder ordered. When they arrive ill give it another go and give an update.
    Appreciate the help!
    J
  12. The Following 2 Users Say Thank You to JDM22 For This Useful Post:
    mudnut (17th September 2021), mudski (16th September 2021)
  13. #10
    May 2016
    8 Post(s)
    slave cylinder gets hot from the exhaust and goes awol !
