Results 1 to 3 of 3
Thread: Oil pressure TB42E
    Jul 2021
    Gippsland Victoria
    Oil pressure TB42E
    What should the oil pressure gauge on my old (380k+klm) GQ dual fuel indicate at normal highway speeds ?
    At approximately 100kph and 2200rpm, oil pressure sits at about 6 for the first 5 to 10 klm then slowly drops to just over 4 on the gauge. It remains happily at that figure until the trip is finished - several hours. I have changed oil and filter but this has made no difference. Is this anything to worry about?
    Jul 2021
    Gippsland Victoria
    Thanks for all the helpful replies. The forum has been a great help....not!
    I missed this thread. Considering aged Nissan Gauges are more like guidelines than rules...
    Oil gets thinned out as it heats up, so the pressure does drop. 4 is OK. Check the connector at the oil switch, just in case it has come loose, corroded or the wires are loose at the crimp. Mine gained half a point when I replaced the lugs.
