Results 1 to 3 of 3
Thread: tracking down whirring noise.
    Oct 2020
    Hi to all,poopsie here again,still trying to nail down slight whirring noise when clutch is released on the ls3 conversion.I had the idea of putting transfer case in neutral,engine running,and going thru the gears.On all gears when releasing the clutch the noise was present except in fourth gear .This leads me to believe the input bearing is fine,the transfer case is fine,so I am thinking the preload on the input shaft has changed with the fitting of the marks adapters bell housing and input shaft extension and the noise is just the gears bedding in again.Does anyone think that this could be the noise.Thanks guys.
    North brissy
    It could just be gear noise and it disappears in 4th cos it's 1:1.
  4. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    mudnut (11th September 2021), Stropp (11th September 2021)
    Oct 2020
    thanks old mate I think you are right and I hope you are right,The vehicle drives great,clutch and gearbox work well.
  6. The Following User Says Thank You to poopsie For This Useful Post:
