Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: road worthy for the camper
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by hekarewe View Post
    yes it is a tent on a trailer but the stove is perminantly fix to the trailer and the bottles are plumb through the body work so they to become part of the unit,,, as such it requires a gas certific to say that iot is safe pull on the road and the fittings are the right ADR standards and dont leak etc same as the gas fittings on a caravan.
    thanks for the reply---dumb ass rego joint should have all the contacts aye,well the plumbers should be able to help or any gas fitting shops try the autogas shops
    good luck with it
    roofy
    Patrol Freak hekarewe's Avatar
    Feb 2011
    springfield lakes
    the plot thickens LOL well just given a bum steer by QLD traffic,,, not any LPG fitter can do the GAS cert for the camper,,,,, it is the same as a caravan apparently and needs to be inspected by the same people as doing the caravans. so have found a place over at eightmiles plains that does caravans and will do my camper will post his details up here on friday when I get them in case anyone else needs his services.... as for the road worthy found M & D mechanical over at coopers plains who do trailers and have will put his details up as well once i get them on friday
  4. #13
    Feb 2011
    springfield lakes
    right well as you would already know by a post on the scenic rim thread i have finally regoed the camper!!!!
    $35.00 for the road worthy
    $80.00 for the gas cert
    $112.00 for the rego
    they saw me coming
    now seeing as there are bugger all people doing the gas cert now as they (QLD traffic) keep changing the laws on gas compliance, just scrapped by on my gas cert as mine was built in QLD in 2010 and that time the gas bottles could be mounted on the side of the trailer. NOW they must be mounted on the front or protected in some way from colission in case they explode. any whoooo i sweet talked the gentleman into seeing things mine way and giving me a pass.
    gas cert from;
    Youngs caravan hire
    073341 5599
    www.ych.com.au
    320 millers rd
    underwood
    i can put up the name of the gent who did the road worthy as he is trying to retire and only does them on referral from a select few people. sorry guys
  5. #14
    TRAFALGAR VIC
    35 Post(s)
    they saw me coming
    now seeing as there are bugger all people doing the gas cert now as they (qld traffic) keep changing the laws on gas compliance, just scrapped by on my gas cert as mine was built in qld in 2010 and that time the gas bottles could be mounted on the side of the trailer. Now they must be mounted on the front or protected in some way from colission in case they explode. Any whoooo i sweet talked the gentleman into seeing things mine way and giving me a pass.
    Gas cert from;
    youngs caravan hire
    073341 5599
    www.ych.com.au
    320 millers rd
    underwood
    i can put up the name of the gent who did the road worthy as he is trying to retire and only does them on referral from a select few people. Sorry guys
    must be a good camper mine cost $35 to regestar
  6. #15
    Feb 2011
    springfield lakes
    camper tares in at 750kg's an extra kilo would have made it $80 dollars deerer
  7. #16
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    So you had the spare wheel, the gas bottles, the Jerry cans, the water tank, the poles etc etc off it to make the weigh in and now you put it all back on it sits at 1.3 ton??!!!! lmao
    Glad you got it sorted mate - not many sleeps till you use it again!!!
  8. #17
    TRAFALGAR VIC
    35 Post(s)
    [QUOTE=hekarewe;125321]camper tares in at 750kg's an extra kilo would have made it $80 dollars deerer[/QUOTE
    so did ours,i didnt even take it to vic roads just went in
    described it to the sheila,$35 thankyou went home put the sticker on done
    good luck with yours and hope you get as much enjoyment out of it as we do
  9. #18
    Feb 2011
    springfield lakes
    [QUOTE=roofy;125363]
    god wish it was that easy even after all the inspections the QLD traffic still had to site the trailer and even put the tape over it to make sure it was all in regulation and not over size LOL
  10. #19
    Oct 2010
    Victor Harbor SA
    Interesting article in the Sunday Mail (Adelaide) today about dodgey caravan manufacturers. Appartently anyone can set them selves up as a caravan builder. The problem is that a number of them are not manufacturing to accepted engineering design principles. Instances where peope have paid large amounts of money (high $90,000) to have a van built and when gone to have it registered - to have it rejected.
    In other instances it would seem the caravan manufacturer is able to get them registered without having them independantly certified.
    As one would get someone with some pretty good mechanical knowledge expereince to run the slide ruler over a car they're thinking of buying - the rule also holds good for caravans.
    I'm not sure whether I would have all that much faith in the industry associations - as it would apear that it is self regulatory.
