Results 1 to 2 of 2
Thread: 2008 Patrol Y61 ZD30 DDTi Piston damage #4 and rebuild
    Dec 2013
    Bridgetown WA
    Question 2008 Patrol Y61 ZD30 DDTi Piston damage #4 and rebuild
    My Patrol has done about 115,000 km and pulling a 3 ton van up long gradual incline near Kalgoorlie in too higher gear, burnt a piston causing crankcase pressure lots of smoke and no power. Now know and am fitting EGT, Oil Can and Boost Gauge.
    Anyway have lifted motor out and disassembled. Honed cylinders(no real damage), new standard pistons/rings (Teikin Alfin Gallery) through UMR Parts ; lapped valves etc and am assembling. I have purchased ThreeBond 1215 Liquid Gasket for where required as it is for differentials and transmissions. However on the instructions it states if sealing oil pan or sump, to use a different product. As it is a major job to removed the engine again to fix an oil leak on the sump and pan, Can anyone advise what liquid gasket would be best for that purpose. Your advice appreciated.. Tks .. Rick
  2. The Following 2 Users Say Thank You to Rickaty For This Useful Post:
    growler2058 (28th August 2021), Stropp (29th August 2021)
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    I have used high temp silicone to seal sumps with much success
    You have to clean the surfaces with thinners first though
    2008 CRD Auto Wagon
  5. The Following User Says Thank You to pollenface For This Useful Post:
    Rickaty (29th August 2021)
