13th August 2021, 10:36 AM
Scangauge 2 and transmission temps
Hi Everyone,
Is anyone using a Scangauge 2 to monitor transmission temps in their Y62 ?, what temp ranges are you seeing ?, are you towing circa 3T ?
The training manual for the vehicle states that this transmission obtains much of it's improved efficiency from having the lock up function at a lower RPM and higher power setting, what RPM does it lock up ?, does it stay locked up even at full power ? (Scangauge 2 Torque Converter temps would answer all of these question)
Thanks in advance.
13th August 2021 10:36 AM
