Results 11 to 20 of 32
Thread: TD42 Losing boost pressure
    404 Post(s)
    Been locked down too long. Taking it for a drive and absolutely sink it. She'll boost in no time I reckon. lol
    Haha tried that.
    295 Post(s)
    Ö.anyone say Y62
    Me! Me! Me! It was Me!......
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    mudski (4th September 2021)
  5. #13
    295 Post(s)
    Update.
    My Patrol is just sitting here. Lol.
    Boost controller is fine, so are all the hoses and the IC is fine. Changed out the fuel filter and it didn't help. Theres no gauze screen on the inlet line going into the pump. So its either the motor or injector pump. I assume. In lockdown so no rush.
    I would say yoy have a boost leak for sure. That explains the lack of boost and the black smoke as it is tuned for more boost so over feeling now. I woyld be tracing every boost hose looking for a split or blown hose . You may fine it just with the bonnet up and someone revving up the car.
  6. #14
    404 Post(s)
    Already done this mate. Replaced every boost hose in there now. The only thing I haven't checked is the intercooler. But being a barely used Cross country Ic I doubt its the cause. I will look more into a few things when the weather warms up.
  7. #15
    409 Post(s)
    Big Stogie Cigar trick possibly Mark Mate
    Smoker or not, fill your cheeks with a massive cloudy gob full and pressure witness visually test that aluminium radiator thingy
    mudski (5th September 2021)
  9. #16
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    9 Post(s)
    Have you taken a reading directly from the compressor with the wastegate firmly closed?
    John
  10. #17
    404 Post(s)
    No. How do I do that?
  11. #18
    Morayfield, QLD
    9 Post(s)
    Connect the gauge hose directly to the compressor housing outlet and remove the hose on the wastegate actuator.
    Donít go silly with it in case it boosts high before it overcomes the actuator spring
    The compressor outlet will currently be connected to your boost controller which then feeds back to the actuator.
    I assume your gauge hose is connected to your IC or manifold?
    John
  12. The Following User Says Thank You to jff45 For This Useful Post:
    mudski (6th September 2021)
  13. #19
    404 Post(s)
    Yes my gauge reads from a port in the inlet manifold. Then another port T'd (one to the injector pump, one toward the boost controller), then to another T, (one to the boost controller and the other to the wastegate actuator) Apparently its plumbed like this for high boost applications.
    So what should i see doing as you suggest John? What shouldn't I be seeing?
  14. #20
    295 Post(s)
    You will be taking out the intercooler. straight off the actuator will show you the boost output at the turbo
  15. The Following User Says Thank You to MudRunnerTD For This Useful Post:
