Results 21 to 30 of 32
Thread: TD42 Losing boost pressure
    461 Post(s)
    You will be taking out the intercooler. straight off the actuator will show you the boost output at the turbo
    Ahh ok.
    I don't have a boost port pre intercooler though. Or am I missing something?
    Ahh ok.
    yeah the hose nipple at the actuator is pre intercooler.
  4. #23
    461 Post(s)
    Hmm.
    Right. This is something I've never played with so its all new to me. So all Im doing is removing the boost hose from the controller to actuator? Go for a spin and see what I get in boost pressure?
  5. #24
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Hmm.
    Not quite. What I’m suggesting is to read the boost that’s coming directly from the turbo to eliminate any issue with the wastegate.
    On the turbo compressor housing there will be a barb where the boost pressure is sent to the entry side of your boost controller. Something like the brass barb on my P4x4:
    You need to take the hose from your IC, or wherever the boost gauge gets its reading, and connect it directly to that barb so the gauge reads the boost the turbo is making. You’ll almost certainly have to lengthen it to reach.
    That should completely isolate your boost controller and the boost will have no effect on the actuator.
    John
  6. #25
    461 Post(s)
    My Turbo doesn't have that barb as per pic.
  7. #26
    Morayfield, QLD
    Ok, in fact, if you have a boost leak in the system then it will be down on boost anyway.
    John
  8. #27
    461 Post(s)
    I spoke with a customer yesterday who's a TD nut and he told me to use my air compressor and run 5psi and then in 5 psi increments directly into the actuator to see if it moves and when, as he said its likely either the actuator is kaput or even the wastegate springs have broken. So I'll attempt this over the weekend.
    Stropp (7th September 2021)
  10. #28
    Morayfield, QLD
    That's why I was suggesting testing boost directly with the wastegate firmly shut. If the spring is broken inside the actuator, although I've never heard of that on any forum, you should be able to just feel the loose actuator rod with your fingers.
    John
  11. The Following User Says Thank You to jff45 For This Useful Post:
    mudski (8th September 2021)
  12. #29
    461 Post(s)
    Ahh ok. I wasn't sure what you were actually trying to find with this. Makes sense now. Sorta. i've never had to dabble in this part of the TD's so its all new to me.
  13. #30
    461 Post(s)
    Update. So I clamped the boost line shut to the actuator. Took it for a spin and wow! Full boost and she screamed!
    Just got to figure out what this means. What part has failed to cause this. The controller is merely a needle valve which restricts air flow. It works. I can wind it right in and it shuts off flow. So I can’t see this being the cause, but who knows.
    Atleast I’ve made some progress.
  14. The Following 2 Users Say Thank You to mudski For This Useful Post:
    jff45 (13th September 2021), Rossco (13th September 2021)
