Results 1 to 7 of 7
Thread: 98 nissan patrol air mass issue
    Aug 2021
    I have nissan patrol 98 4.5 i have problems with air flow senser i have replaced it with new one still have code p0100 and lot of black smoke and engine shutdown it self after 2 second
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    If the MAF sensor isn't the problem then it's likely to be an issue in the wiring circuit or the plug. You'll need to check that the MAF is getting a 5v signal and, if so, check that the varying voltage between 0.5v (approx.) and 5v is getting back to the ECU.
    John
    Aug 2021
    Can i have wiring diagram for maf sensor
    Coz the wire broke
    Morayfield, QLD
    13 Post(s)
    My mistake, MAF has 12v not 5v. Confusing it with TPS.
    This is the diagram from the factory manual.
    John
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Years ago I had a faulty MAF sensor replaced and the problem was still there. After a lot of head scratching the brand new sensor was found to be faulty. If you know someone with the same type of Patrol just swap their sensor to see if it works.
  6. #6
    Aug 2021
    Tried same issue
    Now garage guy says need new ecu
  7. #7
    Aug 2021
    Finely got it working no black smoke but there is back fire 😢😅
