Results 1 to 3 of 3
Thread: GQ TB4.2E speedo not working
    Aug 2021
    Hi guys,
    I bought my first Patrol 2 weeks ago..so still learning alot!
    The speedo on the dash does not work/move. Any ideas where I could start to figure out the problem?
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    The sender is on the upper drivers side of the Transfer Case. I use a battery drill with a square drive bit to run the sender. With a multi meter set to AC volts connected to the output wires you should see the voltage rise as the speed increases.
    Aug 2021
    Thank you, I'll give that a try. I'll let you know how it goes 😀
