Results 1 to 4 of 4
Thread: Tb42 Timing
    May 2021
    Tb42 Timing
    got a tb42efi the idles like its trying to stall and has a rev limiter at 3000 rpm on petrol but runs very well on gas could the issue with the petrol be fixed with some timing changes
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Easy stuff first. Look for a vacuum leak. Maybe a hose or inlet piping, sensor or inlet manifold gasket. Dual fuel is always a compromise.
  4. The Following User Says Thank You to mudnut For This Useful Post:
    ChunkTB42 (6th August 2021)
  5. #3
    May 2021
    thanks mate it was the MAF sensor causing the problem as the connector wasn't working properly.
  6. #4
    SW Vic.
    80 Post(s)
    Thank you for the feedback, as it might help others. Glad it was an easy fix.
  7. The Following User Says Thank You to mudnut For This Useful Post:
    ChunkTB42 (17th August 2021)
Tags for this Thread
