Results 1 to 6 of 6
Thread: GU 4.5 Petrol Need to empty fuel tank
    Jul 2021
    Adelaide
    Hi All
    what's the easiest and quickest safe way to empty the petrol tank?
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Through the floor in the rear.
    John
    Jul 2021
    Adelaide
    Thanks John do you know of any images of the procedure?
    Morayfield, QLD
    Mate, you shouldn’t need pics if you take a look. Take the cover off and unscrew around the sender unit and take the lot out.
    It will give you room to get your hands in there to clean if needed.
    When I converted to diesel I syphoned the petrol out and wiped the inside with a clean rag
    John
    192 Post(s)
    There should be a drain plug too on the bottom, but maybe all don't have it. .
    Jul 2021
    Adelaide
    Thanx again
