Results 1 to 3 of 3
Thread: GQ damp floor
    Advanced sussgq's Avatar
    Dec 2020
    GQ damp floor
    gday legends, i was wondering if anyone has any hints or tips for where this water would be coming from in my gq? evap is there but no ac so not that, have heard they can leak from the air supply to the heater fan?
    also not coming through the wire grommets in pic cause i pulled them back and all wires were dry.
    or could it be that i just had a windscreen and seal replaced improperly, thankyou!
    192 Post(s)
    Hey mate, the scrivets that run along the scuttle panel can be a culprit sometimes. Check they're all there and can run a bit of silicone over them too to double make sure if you like. . The area certainly looks like the drain for ac would be likely suspect but if no ac then shouldn't be I suppose. Maybe take the hose off and check its all clear and dry, I've had the outlet block before then the box fills up till it overflows, wishy checking I spose. .
    Dec 2020
    the scrivets in the scuttle only go into the cab on gu’s as far as i know. i had the scuttle panel off recently to clean it out and can feel the bottoms of them all reaching in.
    i worked it out that it’s the grommets where those wires run through, leak a little bit when washing the car
