Thanks rossco I hope that’s what it is, I may just leave it for now and hopefully get up for you guys to have a listen and see, the original owner said it maybe the problem too and it was tuned in a warmer climate!
Yeah I was in the hope to get mine perfect but think it is 12mm thing, having seen many other 12mm TDs in the cold they all vary somewhat but overall tend to be be a bit rough on cold starts. . Mine even is a little unpredictable sometimes cold start is fine other times pops & smokes a fair bit but then all good. . At the end of the day is mechanical injection with more fuel and no boost on idle / startup so when frosty can't burn all fuel efficiently. Could do compression test for peace of mind and check glow plugs but certainly wouldn't worry about pulling the motor . .
