Results 21 to 30 of 34
Thread: New winch needed or not??
    49 Post(s)
    Neither, in cab. I can hear the solenoid clicking even when the motor isn't moving
    Maybe the solenoid contacts have carbon on them, or have been misshapen by excessive heat.
  4. #23
    49 Post(s)
    Maybe...
    I got no f@#ken idea.
  5. #24
    194 Post(s)
    @jaysee, its only on the wrong terminal when you let the smoke out! Looks like just another small problem to resolve, good luck.
    jay see (17th July 2021)
  7. #25
    49 Post(s)
    Did some more testing today.
    1st.
    I tested as per the video that pb put up and no difference.
    2nd
    I tested the solenoid.
    Hope it makes sense.
    Conclusion. Which runva to get..
  8. #26
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    If you are satisfied that it is the contactor/solenoid, I have this Warn one that you can have if it is suitable. It is out of a 10,000lb unit that the gears failed after only a couple of minor uses but a lot of water ingress into the winch (but not the controller).Warn contactor.JPG
  9. The Following 4 Users Say Thank You to Brissieboy For This Useful Post:
    Avo (19th July 2021), jay see (19th July 2021), mudnut (19th July 2021), PeeBee (19th July 2021)
  10. #27
    49 Post(s)
    Quote Originally Posted by Brissieboy View Post
    Thanks Brissie, but I think I'll be going a new everything..
  11. #28
    175 Post(s)
    I have the 13XP premium which are low in stock everywhere from what I understand. Great bit of kit.
    But 11 should suffice too .
    Look at the specs on the website and make a call from there.
  12. The Following User Says Thank You to Hodge For This Useful Post:
    jay see (20th July 2021)
  13. #29
    If you are going to get rid of your current winch, and control gear, maybe at a meet up, I can grab it off you for a price and have a go repairing it. I've wanted to tear down a Runva to see how different it is from my Aldi unit.
  14. The Following User Says Thank You to mudnut For This Useful Post:
  15. #30
    49 Post(s)
    I sent runva an email asking if the 13xp would fit with my Raslarr bar.
    Thank you for getting in touch.
    I don’t think the 13XP Premium will fit unfortunately. The 11XP Premium will however fit perfectly and a great option for a GU patrol.
    Is it correct that you the winch capacity should be double the weight of the car?
    I'll probably keep the solenoid as a spare, I didn't think that there's anything wrong with it and the rope as it's only been used to pull out a couple of yaccas, but you're welcome to the winch for nothing.
    I know a few years back the ALDI winch was the same as the Ironman. My current one is a t-max winch the runva is what I'm going to replace it with.
