10th July 2021, 08:00 PM
No charge light no power to exciter wire
Gidday All was hoping to pick your brains, Got a 2014 GU I'm have no power to the L wire (exciter) and no battery check light on dash with ignition on.Alternator has been tested by auto elec. Battery is good Have checked all fuses all seem good.I've got power to sense wire and B+ wire at alternator. any ideas what else i should be looking for Cheers
10th July 2021 08:00 PM
10th July 2021, 08:08 PM
Patrol Freak
Maybe the charge light bulb?
John
10th July 2021, 08:18 PM
Yer checked dash There is no bulbs presume its leds on circuit board
18th October 2021, 10:39 AM
not an alternator guru but could you add another loop, one that would incur a voltage drop to initiate charging?
2008 CRD Auto Wagon
Factory snorkel, flashlube catchcan pro, 3" manta exhaust, hpd boost controller, dyno-tuned & egr deleted
The Following User Says Thank You to pollenface For This Useful Post:
PeeBee (18th October 2021)
