Results 1 to 4 of 4
Thread: No charge light no power to exciter wire
    Apr 2018
    Perth WA
    Gidday All was hoping to pick your brains, Got a 2014 GU I'm have no power to the L wire (exciter) and no battery check light on dash with ignition on.Alternator has been tested by auto elec. Battery is good Have checked all fuses all seem good.I've got power to sense wire and B+ wire at alternator. any ideas what else i should be looking for Cheers
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Maybe the charge light bulb?
    John
    Apr 2018
    Perth WA
    Yer checked dash There is no bulbs presume its leds on circuit board
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    not an alternator guru but could you add another loop, one that would incur a voltage drop to initiate charging?
    2008 CRD Auto Wagon
  6. The Following User Says Thank You to pollenface For This Useful Post:
    PeeBee (18th October 2021)
