Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Front slotted brake rotors - which ones?
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    I'm looking at rejuvenating brakes after 20 years and searching around I see quite a few people like the RDA slotted & dimpled type but I don't really see the need for dimpled with today's non-asbestos pads.
    I like the look of the DBA T2 slotted only discs which are about $100 dearer but I suspect that's because of Australian wages.
    I never did my brake lines when I lifted the Patrol 80mm so I have a set of braided extended lines turning up today. I have Yellowstuff EBC pads already in the front that aren't very old so I won't change those.
    John
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Hi John,
    I punted for the DBA slots, Made a fair difference, less overshooting corners, fewer skidmarks on the passenger seat.
    Be interested in your opinion re braided lines,
  4. The Following User Says Thank You to Touses For This Useful Post:
    jff45 (8th July 2021)
    Morayfield, QLD
    13 Post(s)
    I’m expecting the braided lines to give a slightly firmer pedal but mainly because the original rubber lines are now 20 years old.
    At a guess, I’d say new rubber lines would probably feel better too but then I wouldn’t be able to say “I’ve got braided lines”
    John
  6. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    growler2058 (10th July 2021), Touses (8th July 2021)
  7. #4
    Ballarat, Vic
    174 Post(s)
    I'll be interested too. I have the RDA slotted & dimpled with EBC Yellowstuff pads & suspect braided lines would give a better feel, but have never tried as the combo I have now seemed 'good enough' compared to the original 'deathwish' items. If the hoses need replacing, there seems little reason not go with with braided!
    When I first bought our Patrol (almost 6 years old at the time) I thought the sponginess of the brakes indicated a need for the brakes to be bled. The dealer who sold me the car agreed to pay for me to take it to my local Nissan dealer. They bled them & it still felt the same. When I complained the manager got me to sit in another customers car to demonstrate 'They are all like that, Nissan consider it safer for off road use'
    When I overshot a turn because the brakes couldn't slow me enough from a fairly modest speed it scared me enough to fork out for the RDA's & EBC pads - only on the front - still have the original drum brakes on the rear.
  8. The Following User Says Thank You to Cuppa For This Useful Post:
  9. #5
    Morayfield, QLD
    13 Post(s)
    I’ve ordered the DBA slotted discs from Sparesbox on eBay. They were doing 14% off so they’re $25 or so more than the RDAs.
    It was mainly extended lines I wanted but braided as well, why not?
    John
  10. The Following User Says Thank You to jff45 For This Useful Post:
    Cremulator (8th July 2021)
  11. #6
    461 Post(s)
    I have braided lines all round and the difference alone in just these when first fitted was definitely noticeable.
    I then went to TB48 route with the master cylinder, calipers and rotors (slotted) using OEM pads and when I got the Patrol engineered the comment I got back was he'd never been in a Patrol that stopped so well.
  12. The Following User Says Thank You to mudski For This Useful Post:
    jff45 (9th July 2021)
  13. #7
    Morayfield, QLD
    13 Post(s)
    I couldn't justify that kind of expense for the amount of use I give mine. I've only done 25,000 kms since I converted it to TD42T in 2015.
    Also taking into consideration the way I drive now at my age
    I found the EBC Yellowstuff pads alone made a noticeable difference.. and so they should for the price.
    John
  14. The Following User Says Thank You to jff45 For This Useful Post:
    growler2058 (9th July 2021)
  15. #8
    Feb 2011
    Shed
    45 Post(s)
    I just ordered these as well. I was looking at them on eBay after reading this thread. Nekminnit email saying discount discount discount. SOLD $262. Pads next
  16. #9
    Feb 2011
    Shed
    45 Post(s)
    Gee whiz! Those yellow stuff pads are freakin’ exxy $$$$$
  17. #10
    Morayfield, QLD
    13 Post(s)
    Which is why I made the comment that they should work for that price
    John
  18. The Following User Says Thank You to jff45 For This Useful Post:
