23rd June 2021, 10:47 AM
Drive shaft axial end play GQ and GU difference
Hi guys
My td42 Y60 has Y61 auto lock free running hub, and wheel bearing lock nut system fitted.
I am confused because the GQ manual states that the end play between the snap ring and the mating parts should be 0.2mm or less. However the GU manual says 0.4mm or less. Since my axle has the GU locking hub and wheel bearing lock nut fitted Im thinking to use 0.4mm as the tolerance.
Im looking for any guidance some one could provide?
23rd June 2021 10:47 AM
