Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 71
Thread: TD42 Compression Test Results Query Please Team
  1. #51
    472 Post(s)
    Must say it’s a fairly heavy little nugget of a thing unpacked just now, hopefully heavy means quality to get me temporarily back up over the massive mighty 60rwkw mark it mite
    FWIW: Do NOT pull the little rubber bungs out of each end to blow test the inbuilt one way check valve …….it’s full of factory packaging oil and now all over the kitchen table…….idiot MB style
    Interestingly within the installation instructions it suggests the optional Holley 12-810 Oil Pressure Safety Switch (petrol applications) to cut off supply when oil pressure drops below 5psi which I never knew such a safe guard existed:
    https://www.holley.com/products/fuel...s/parts/12-810
    Thinking that when I’m finished with it and when time comes to properly fix up the old TD42 I might switch it over to the Daughters TB45 as whatever elecy pump is under its floor pan currently sounds like a million Bees buzzing and I’m not confident She’ll keep a proper eye on OEM dash warning lights
    Again, I really do appreciate your advice Craig, John, Ross, Mark, Andy, Phil & Mat Mates
    Your helpful posts have not fallen on deaf ears and I will build plan on a Carter pump in the future along with other TLC power upgrades Old Grandpa Spec deserves in the future.
    Cheers Legends!!!!!
  2. The Following 5 Users Say Thank You to MB For This Useful Post:
    jff45 (30th June 2021), mudski (30th June 2021), nissannewby (30th June 2021), PeeBee (30th June 2021), Rossco (30th June 2021)
    472 Post(s)
    FWIW (record keeping) :
    Will fit the baby lift pump this week but did replace the $110 Zexel IP shutoff solenoid Friday morning before a quick weekend away up the mountains.
    Wacky own theory was for ruling out any slight chance of it possibly jamming say half way but didn’t appear once removed to have any spring sticking point tested even with near 30 YO wear marks
    FWIW2: An absolute nightmare of an OEM design swap over whilst the IP is on the truck, an expected 15min job turned into over 2hrs
  5. The Following 3 Users Say Thank You to MB For This Useful Post:
    jff45 (5th July 2021), PeeBee (4th July 2021), Rossco (4th July 2021)
  6. #53
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    You’ve just reminded me that one of the items on my list of things to fabricate is a dedicated spanner for that solenoid.
    John
  7. The Following User Says Thank You to jff45 For This Useful Post:
    MB (5th July 2021)
  8. #54
    472 Post(s)
    That’s exactly what it needs John Mate
    A 15/16” open end spanner head cut off with a 1/2” drive socket connection for a long extension drive up top above the intake manifold would make life shiploads easier next time
  9. #55
    Morayfield, QLD
    13 Post(s)
    Isn’t it metric 24mm? I was thinking a thin walled 12 point ring but can’t really remember if a ring will fit over.
    I’ll take a closer look at it
    John
  10. The Following User Says Thank You to jff45 For This Useful Post:
    MB (5th July 2021)
  11. #56
    472 Post(s)
    The 24mm I found slightly sloppy on it and kept trying to butcher the thing on the angle I was on initially, changed over to the 15/16” and was snug as
    Definitely can’t fit a ring spanner over it as is next to zero room on the back side unfortunately.
    I ended up undoing the banjo on the hardline so I could lift it slightly to get the open ended spanner onto it at 90 degrees but then also had to remove 2 of the 3 accelerator cable mounting bracket bolts so I could swing it out of the way for quarter turns at a time.
  12. #57
    sunshinecoast
    3 Post(s)
    lookup crowsfoot socket . it might be what you need to get the job done .
  13. The Following 2 Users Say Thank You to nipagu7 For This Useful Post:
    MB (5th July 2021), PeeBee (5th July 2021)
  14. #58
    Morayfield, QLD
    13 Post(s)
    Maybe a modified flare nut spanner
    John
  15. The Following User Says Thank You to jff45 For This Useful Post:
    MB (6th July 2021)
  16. #59
    sunshinecoast
    3 Post(s)
    you can get crows foot flare nut sockets also
  17. The Following User Says Thank You to nipagu7 For This Useful Post:
    MB (6th July 2021)
  18. #60
    472 Post(s)
    Had to look up the names of them both Thanks Legends (McGoggle images for me :-) but do agree both of them Top Tools Gents could definitely be modified to get the job done next time for us all for sure
    As best as I can remember my nuffy In situ removal/replace seen no way of any ring type socket spanner that had beyond say 180 degree grip/wrap being able to overlap connect due to the pump’s top/side proximity on approximately 120 degrees of its circumference maybe?
    Another issue found when trialling a standard ring spanner intially was that the + connection atop of the solenoid wouldn’t allow a ring to slip over due to its head room from pump casting also if that makes sense?
    All I can say is that Mr Nissan (Injection Pump Division) back in the day never considered some poor Aussie Bloke/Sheila trying to remove and plug with a bung one of the few only things things that might stop a TD42
    “Carry a spare & a speciality McTool” that we can hopefully develop here Old School 4.2 Diesel Stinker Legends
  19. The Following User Says Thank You to MB For This Useful Post:
    jff45 (7th July 2021)
