10th June 2021, 09:11 PM
Glow Plugs ZD30 Common Rail
Trying to work out which glow plugs I need for my 2008 ZD30 Common Rail. I haven't pulled the original ones out yet. However I know that the original Nissan ones (11065MA70A) are NKY (NGK) Y538J. From my searching it looks like these are metal tip, is this correct?
If so, I wouldn't need a timer then.
10th June 2021 09:11 PM
11th June 2021, 07:58 AM
I can't see you needing a timer if the vehicle never came out with one. Have you ran a DMM on your current setup to see how long they are actually on for after startup? Even if it was two or five minutes I wouldn't be concerned. Pot temps on a diesel after a morning startup would be no where near operating and running temps.
Each to their own though.
Pretty sure all NGK glow plugs are metal tipped though.
11th June 2021, 09:18 AM
Just there is alot of talk about adding an aftermarket timer to your vehicle after installing metal tip glow plugs
11th June 2021, 07:19 PM
Flex
The timer thing was for the ceramic tipped plugs. Metal tipped plugs are supposedly more resistant to failure. Apparently.
12th June 2021, 09:35 PM
Flex
Your CRD is a totally different beast to the Di which seems to glow for an incredibly long time.
I have a later model crd and have tested the glow time. It seems to be directly related to engine temp. As soon as operating temp reaches approx 30⁰C it stops glowing. This means it doesnt even glow if starting when already warm. This is completely different to the Di which glows every start regardless of engine temp.
So I havent bothered with a timer because it simply doesnt need it.
Hope that helps
The Following 2 Users Say Thank You to trev zd30 For This Useful Post:
Flex (27th August 2021), pollenface (5th October 2021)
