Tb42 intercooled gas research turbo engine, all items 26000 ks old except bottom end, big front mount intercooler hidden behind grill, all mandrel bent pipe work, got brand new head (not reco) with gas valves and heavy duty crow cam valve springs, have receipt for $1989, gas research s440 throttle body and b2 converter and balance pipe, full electronic scortcher replacement high energy dizzy and coil to suit turbo with advance and retard, turbosmart dual port plumb back blow off valve, genuine temp sender, thermostat, and gaskets used in build, including head gasket, custom made spark plug leads, cooler range spark plugs, new 120amp altenator, monsta t3to4e turbo, denco highmount turbo manifold, all new belts, speco boost gauge, two gas tanks with a usable 168 litres of gas and equalizer valve, gas safety swich, all flexy gas lines, exedy clutch, new 3 inch exhaust from turbo, dumped at diff, sounds great, great oil pressure, runs perfect temp wise also, serviced with nulon oils, has made nearly 200rwkw on 35s. This is a complete engine ready to put in and go, runs great. ENGINE STILL IN CAR.
has had epa certificate of compliance done last year and passed, I have paperwork.
Only issue is the turbos internal gate or wastegate acuator, still boosts fine but will keep boosting if you keep your foot down as if there is no wastegate, can be fixed with external gate which would be better, but its not my daily so haven't changed it,
Runs great still and boosts good.
$3500 FIRM. PLEASE NO TIME WASTERS, GENUINE INQUIRIES ONLY.
comes with spares, b2 converters, gas lock offs and safety switches, Bosch 85 amp altenator, thermostat, radiator hose. And whatever else I can find.
please call or msg Andrew on 0413666805.
Located geelong, Victoria.
