Results 1 to 10 of 22
Thread: Engine Running Sense Wire???
Threaded View
  1. #14
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    If you do want to connect it you can run a wire direct from the ignition or find a suitable fuse and run a fuse tap from down by your right knee. I'm not an auto elec but for the minimal current draw something like this might be your easiest solution;
    https://www.ebay.com.au/itm/2-x-Add-....m46890.l49286
  2. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    10G (7th June 2021)
