Results 11 to 20 of 22
Thread: Engine Running Sense Wire???
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    If you do want to connect it you can run a wire direct from the ignition or find a suitable fuse and run a fuse tap from down by your right knee. I'm not an auto elec but for the minimal current draw something like this might be your easiest solution;
    https://www.ebay.com.au/itm/2-x-Add-....m46890.l49286
  2. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    10G (7th June 2021)
    175 Post(s)
    Just hook up to the ignition. Simple. Renogy a simply using the term "sense" wire. Quick flick through the manual it actually does cut off at a certain volt threshold.
  5. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    10G (7th June 2021), MudRunnerTD (6th June 2021)
  6. #13
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    It will charge full time/even if the engine is stopped if you do that. My ctek has the same wire, apparently the smart alternators don't always reach the "on voltage" required to activate the charger so you need to connect that wire to a 12v ignition source. You can try it without it, my (Gu) alternator looks close to standard(non smart) voltages. I've never seen mine drop below 12.7 when running and usually hits 14.1 when first started.
    I did say “if it really needs that wire connected” to turn on. The VSR should handle it from there. I don’t believe it will continue to charge until the main battery runs flat.
    My Projecta IDC25 continues to charge when I switch off until the main battery gets down to 12.7v
    Just had a look at the Renogy wiring and it apparently needs that wire to switch it on. Strange if it has a VSR already..
    John
  7. The Following User Says Thank You to jff45 For This Useful Post:
    10G (7th June 2021)
  8. #14
    Jan 2017
    South Australia
    11 Post(s)
    I wasn't trying to be short with ya mate. I never ran the main battery down far enough through the ctek to see what voltage it would stop at. I assume you're right and wouldn't run it flat. Nice to shut it down with 2 batteries at full charge though.
  9. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    10G (7th June 2021)
  10. #15
    175 Post(s)
    My Intervolt is the same, if its on the "Ignition" option it will ONLY run if IGN is on and will only cut off if minimum volt threshold is reached.
    But there is a voltage sense option too.
  11. The Following User Says Thank You to Hodge For This Useful Post:
    10G (7th June 2021)
  12. #16
    Morayfield, QLD
    I wonder why they have that option. It obviously can’t be switched on when it’s getting solar input so why have it with vehicle charge.
    12.7 is normal standing voltage for a battery so it’s not like the DC/DC is hurting the main battery when the vehicle is switched off.
    John
  13. The Following User Says Thank You to jff45 For This Useful Post:
    10G (7th June 2021)
  14. #17
    175 Post(s)
    Intervolt will kick the unit into action if it detects Solar volts. But in IGN mode, it will entirely isolate its self from main battery if IGN is off, no matter what.
  15. The Following User Says Thank You to Hodge For This Useful Post:
    10G (7th June 2021)
  16. #18
    I haven't had anything to do with the Renology stuff but every other Dc/Dc I have installed/played with the "sense wire" is only req'd if the vehicle is a smart alternator config.
    Old school vehicles you leave that wire disconnected and the VSR does all the work.
    The sense wire is there if/when the Alt drops below the VSR cutout due to the "smart" Alternator function of the ECU dropping to, say 12.8.
    The sense wire input then overrides the VSR low volt cut and the DC/DC keeps working.
    If you do need the sense wire connected on a "dumb" Alternator vehicle to get the Renolgy to work at all then any of the "Ign On" circuits will be your best bet
  17. The Following User Says Thank You to the evil twin For This Useful Post:
    10G (7th June 2021)
  18. #19
    May 2016
    lower west victoria
    30 Post(s)
    Ah, I think you guys are looking at the combined DC-DC & MPPT models. I've got just the DC-DC model & a seperate MPPT charge controller. See below ...
    I went this way as the seperate MPPT can take up to 100v solar input, where as the combined unit can take up to 25v solar input, it's a more efficient way to use the solar panels I have.
  19. The Following 3 Users Say Thank You to 10G For This Useful Post:
    0-TJ-0 (7th June 2021), jff45 (7th June 2021), trev zd30 (12th June 2021)
  20. #20
    May 2016
    lower west victoria
    30 Post(s)
    Thanks 0-TJ-0, that's what I'm looking for. Do they call those adaptors 'add a circuit' or something??? Anyway, bloody useful.
  21. The Following User Says Thank You to 10G For This Useful Post:
