Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Engine Running Sense Wire???
  1. #21
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    I haven't really ever thought of using them but a couple things I've ordered recently came with them pre-installed. I don't use them because I have some easy access ign/acc points already setup. Perfect for simple little things like you want though.
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    I soldered a wire to the back of a cigarette lighter socket to use as a sense wire for relays and things.
    Alternatively you could go with a voltage sensing relay which only connects when the alternator is making upwards of 13.3v
    2008 CRD Auto Wagon
