Results 1 to 6 of 6
Thread: Trailing arm bushes
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Trailing arm bushes
    It's come time to replace the bushes around the rear diff I think. It's hard to see but I think they're cracking and there's a ton of what feels like backlash when changing gears. The diff and gearbox all feels okay with a jiggle of the tail shaft. I assume they've never been done so won't hurt for a freshen up anyway.
    I'm leaning towards just throwing a set of genuine bushes back in. Anyone using aftermarket stuff? Any running cheaper ones or nolathane? I figure the cheap ones I'll just be replacing in the short term and I don't think I have any need for nolathane but be interested to see what people think.
  2. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    MB (31st May 2021)
    473 Post(s)
    OEM for the win TJ Mate, any decent shop should will advise the same too
    The issue with Nolathane is once they slightly crack it aint too much longer until they’ve completely fallen out, OEM rubber will give you plenty of warning to replace sometime soon, not in the middle of an adventure hopefully is my experience
    0-TJ-0 (31st May 2021)
  6. #3
    OEM lasted this long. Use them again for the win. Any decent shop will get it done.
  7. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    0-TJ-0 (31st May 2021), MB (31st May 2021)
  8. #4
    Jan 2017
    South Australia
    11 Post(s)
    That was my thoughts and I thought would be the same in here. Just thought it was worth asking the question, especially with the nolathane stuff.
    I have access to a press and a hoist so I think it'll be an easy enough job for me..hopefully this time next year I'll have access to my own if the council approvals ever come through.
  9. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    MB (31st May 2021)
  10. #5
    473 Post(s)
    It’s just another trademarky brand name for Polyurethane I believe TJ Mate! Great performance very early on installed but unfortunately its tough/hard yet brittle makeup has let me down in younger days very fast
    Rubber quality is extremely variable too, synthetic variants (cheap stuff) suffers nearly the same fate I’ve found too.
  11. #6
    Jan 2017
    South Australia
    11 Post(s)
    Thanks mate. I had a bit more of a read around and people seem to think they get a bit more flex out of the rubber too. Makes sense, I know the urethane ones are rock hard.
  12. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    MB (1st June 2021)
