Results 1 to 2 of 2
Thread: Fuel gauge sender problem
    Jan 2020
    SA
    I have a 2003 GU ZD30 Patrol and my main tank fuel gauge reads 1/2 full when empty. I removed the Main tank fuel gauge sender unit and checked the float position manually and it will not read Empty when at bottom of float travel, it reads Full when at top of travel. Has anyone had a similar problem and how do you fix it.
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    I suspect the resistive wire is broken somewhere near the halfway point, or the metal finger is losing contact. If it is the latter, then you might be able to adjust it to make a good contact as it slides. If the wire is broken, then you need to get a new sender unit.
