18th May 2021, 07:04 PM
Gq won’t crank over
Hi all,
What would be causing starter motor to not even spin.have checked battery is charged, fuses replaced, wires are connected properly to starter have even tried using a different starter motor.any help would be appreciated.
18th May 2021 07:04 PM
18th May 2021, 07:09 PM
1) battery earth connected to body/block?, 2) do you get dash lights or headlights?, 3) fuseable link blown? Since you have swapped out two starters, unlikely its the starter I would say. 4) worn ignition switch? Stabbing in the dark a bit. 5) re-check cable integrity from battery to starter.
18th May 2021, 07:38 PM
Thank you, will check cable integrity tomorrow. Have got earth from battery,body,block. And have all dash lights and headlights it just won’t crank over, even turned motor over by hand to make sure wasn’t locked up
18th May 2021, 07:50 PM
Do you own an Auto ?.............. Dodgy inhibitor switch?
20th May 2021, 04:51 PM
Update-wired up old starter again and miraculously cranked over now it’s just having trouble starting 😞brand new fuel pump,brand new injectors,brand new plugs,cranks over quick and have checked for spark.
20th May 2021, 10:54 PM
Do you have fuel at the injectors? Squirt a bit of Start Ya Bastard into the Inlet Manifold (Only a few seconds worth of the spray, as you don't want a huge backfire.) If the engine runs for only a few seconds and stops, then fuel is the problem.
21st May 2021, 10:41 AM
mudnut
Have fuel at injectors and sprayed some start ya bastard down it’s throat but still no luck seems to have spark so I’m all out of ideas
21st May 2021, 11:55 AM
If you have a good, strong spark, it will be a timing issue. Re-check all of the leads are in sequence and that the timing isn't retarded or advanced.
22nd May 2021, 12:05 AM
