Results 1 to 9 of 9
Thread: Gq won’t crank over
    Sep 2020
    Gq won’t crank over
    Hi all,
    What would be causing starter motor to not even spin.have checked battery is charged, fuses replaced, wires are connected properly to starter have even tried using a different starter motor.any help would be appreciated.
    Legendary
    194 Post(s)
    1) battery earth connected to body/block?, 2) do you get dash lights or headlights?, 3) fuseable link blown? Since you have swapped out two starters, unlikely its the starter I would say. 4) worn ignition switch? Stabbing in the dark a bit. 5) re-check cable integrity from battery to starter.
    Sep 2020
    Thank you, will check cable integrity tomorrow. Have got earth from battery,body,block. And have all dash lights and headlights it just won’t crank over, even turned motor over by hand to make sure wasn’t locked up
    Expert Arfa Brayne's Avatar
    Jul 2016
    Do you own an Auto ?.............. Dodgy inhibitor switch?
    "Can't" is a dirty 4 letter word.
    Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
    Sip on the "t", and consider what you've got left to work with
  6. #5
    Sep 2020
    Update-wired up old starter again and miraculously cranked over now it’s just having trouble starting 😞brand new fuel pump,brand new injectors,brand new plugs,cranks over quick and have checked for spark.
  7. #6
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Do you have fuel at the injectors? Squirt a bit of Start Ya Bastard into the Inlet Manifold (Only a few seconds worth of the spray, as you don't want a huge backfire.) If the engine runs for only a few seconds and stops, then fuel is the problem.
  8. #7
    Sep 2020
    Have fuel at injectors and sprayed some start ya bastard down it’s throat but still no luck seems to have spark so I’m all out of ideas
  9. #8
    SW Vic.
    80 Post(s)
    If you have a good, strong spark, it will be a timing issue. Re-check all of the leads are in sequence and that the timing isn't retarded or advanced.
  10. The Following User Says Thank You to mudnut For This Useful Post:
    mudski (21st May 2021)
  11. #9
    472 Post(s)
    Not sure if the Petrol Trols have a vacuumy thingo on the end of the fuel rail same as our paddock D20 Navara ute? Either way it has finally/instantly stopped dead after many years of faithful work and I too have blue spark & full fuel pressure to the rail
    Going to float it down to a petroleum mechanic next week as I’m out of ideas too!
    Can only assume it’s the vac system and or bloody aftermarket LPG electrical bullshart
