17th May 2021, 09:28 AM
GU Patrol Cummins 6BT build vlog
Hey folks
Pretty new to the whole YouTube thing but having a fair crack at it! If you like these build vlogs would love a like, sub, and a share to ya mates. 👌🔥
https://www.youtube.com/watch?v=SFet4ZV4Tvo
This one is getting a 215hp out of a Dodge, shipped over from the 'states. Behind that will be a 4L80E built by wholesale auto
Will do a build vlog all on youtube at the link above if you're interested in following, but also might post tidbits and stuff here For example... had a 'real' first start vid, then decided to clean up a bit and do it again for the real video. I put the original clip up on my other channel here:
https://www.youtube.com/watch?v=bVWTa5CcBGo
The Following 2 Users Say Thank You to dangerflite For This Useful Post:
FNQGU (2nd September 2021), mudski (17th May 2021)
17th May 2021 09:28 AM
26th May 2021, 09:16 AM
4L80E gearbox is built, cheers to Rod, Trev, and James from Wholesale Auto
https://www.youtube.com/watch?v=W1E8m3xCaTg
26th May 2021, 02:59 PM
Travelling Podologist
dangerflite
Hopefully it will be ok. A friend has a 6BT with much the same power output in his OKA (Approx 6 tonnes) & originally put a 4L80E behind it, but it let him down badly in the middle of the Simpson. He reckons it wasn't up to handling the power & now has an Allison.
28th May 2021, 08:43 AM
215HP is stock, which produces about 600Nm of torque. Not actually much power really given the size of the engine. I'd be very surprised if any reasonably built 4L80E couldn't handle that... Heat is a major killer of auto boxes, you would have seen that in my video above where the lip seals on a piston had melted and failed causing a pressure loss and leading the clutches to slip and be destroyed. In an OKA travelling through sand I could easily see transmission cooling being an issue. I wouldn't be surprised if that was the cause for your mate. Do you know what failed in his 4L80?
The Following User Says Thank You to dangerflite For This Useful Post:
31st May 2021, 06:34 AM
Sorry I don’t offhand. I can ask him, but it won’t be for a while as he is not home at present & I am about th head ‘off grid’ again for a while.
20th June 2021, 06:26 PM
Latest vid, in this one I'm tearing down the 6BT (not completely) to replace all the leaky gaskets and seals. Was great to see the condition of the internals and to know everything is put together properly
https://www.youtube.com/watch?v=LKZrRn-Z55c
FNQGU (2nd September 2021), MB (21st June 2021)
28th June 2021, 07:12 AM
FNQGU (2nd September 2021), MB (11th July 2021)
7th July 2021, 04:12 PM
Looks like you have some nice projects. I enjoyed watching your vids.
The Following User Says Thank You to balwayne For This Useful Post:
11th July 2021, 04:43 PM
pittydaky2235
Where is moderator??
It is important.
Regards.
Your dribble is worse than mine @pittydaky2235………why don’t you start a thread at least half explaining what it is you’re proposing here in regards “advertisement” opportunities strewn across the whole Forum!
11th July 2021, 08:23 PM
Fuck,now that's saying somethin
The Following 3 Users Say Thank You to Avo For This Useful Post:
MB (12th July 2021), Rossco (11th July 2021), Stropp (12th July 2021)
