Results 1 to 10 of 10
Thread: GU Patrol Cummins 6BT build vlog
    Oct 2018
    Cool GU Patrol Cummins 6BT build vlog
    Hey folks
    Pretty new to the whole YouTube thing but having a fair crack at it! If you like these build vlogs would love a like, sub, and a share to ya mates. 👌🔥
    https://www.youtube.com/watch?v=SFet4ZV4Tvo
    This one is getting a 215hp out of a Dodge, shipped over from the 'states. Behind that will be a 4L80E built by wholesale auto
    Will do a build vlog all on youtube at the link above if you're interested in following, but also might post tidbits and stuff here For example... had a 'real' first start vid, then decided to clean up a bit and do it again for the real video. I put the original clip up on my other channel here:
    https://www.youtube.com/watch?v=bVWTa5CcBGo
  2. The Following 2 Users Say Thank You to dangerflite For This Useful Post:
    FNQGU (2nd September 2021), mudski (17th May 2021)
    Oct 2018
    4L80E gearbox is built, cheers to Rod, Trev, and James from Wholesale Auto
    https://www.youtube.com/watch?v=W1E8m3xCaTg
    174 Post(s)
    Quote Originally Posted by dangerflite View Post
    Hopefully it will be ok. A friend has a 6BT with much the same power output in his OKA (Approx 6 tonnes) & originally put a 4L80E behind it, but it let him down badly in the middle of the Simpson. He reckons it wasn't up to handling the power & now has an Allison.
    Oct 2018
    215HP is stock, which produces about 600Nm of torque. Not actually much power really given the size of the engine. I'd be very surprised if any reasonably built 4L80E couldn't handle that... Heat is a major killer of auto boxes, you would have seen that in my video above where the lip seals on a piston had melted and failed causing a pressure loss and leading the clutches to slip and be destroyed. In an OKA travelling through sand I could easily see transmission cooling being an issue. I wouldn't be surprised if that was the cause for your mate. Do you know what failed in his 4L80?
  7. The Following User Says Thank You to dangerflite For This Useful Post:
  8. #5
    174 Post(s)
    Sorry I don’t offhand. I can ask him, but it won’t be for a while as he is not home at present & I am about th head ‘off grid’ again for a while.
  9. #6
    Oct 2018
    Latest vid, in this one I'm tearing down the 6BT (not completely) to replace all the leaky gaskets and seals. Was great to see the condition of the internals and to know everything is put together properly
    https://www.youtube.com/watch?v=LKZrRn-Z55c
  10. The Following 2 Users Say Thank You to dangerflite For This Useful Post:
    FNQGU (2nd September 2021), MB (21st June 2021)
  11. #7
    Oct 2018
  12. The Following 2 Users Say Thank You to dangerflite For This Useful Post:
    FNQGU (2nd September 2021), MB (11th July 2021)
  13. #8
    May 2017
    Looks like you have some nice projects. I enjoyed watching your vids.
  14. The Following User Says Thank You to balwayne For This Useful Post:
    MB (11th July 2021)
  15. #9
    472 Post(s)
    Quote Originally Posted by pittydaky2235 View Post
    Where is moderator??
    It is important.
    Regards.
    Your dribble is worse than mine @pittydaky2235………why don’t you start a thread at least half explaining what it is you’re proposing here in regards “advertisement” opportunities strewn across the whole Forum!
  16. The Following User Says Thank You to MB For This Useful Post:
    jay see (11th July 2021)
  17. #10
    Fuck,now that's saying somethin
  18. The Following 3 Users Say Thank You to Avo For This Useful Post:
    MB (12th July 2021), Rossco (11th July 2021), Stropp (12th July 2021)
