Results 1 to 10 of 18
Thread: Car Dies When Turning Right After Rear End Accident
    May 2021
    Hey guys, just got my car back from the useless insurance people, they said the car runs and drives like a dream, however there is a problem when turning right the engine just dies.
    It doesn't turn completely off just seems to loose all power. Just posting to see if any of you guys have experienced this problem before as I am stumped,
    The other damage sustained from the accident that could relate to this problem is a bent exhaust that is apparently rubbing on the driveshaft, and panel damage and smashed tail lights.
    The car works fine going straight and left but as soon as i turn the steering wheel to the right it dies and only comes back when I turn the wheel straight again.
    Any help is greatly appreciated cheers guys.
    Car is a 98 GU Patrol 4.5L
    461 Post(s)
    Does it do this when stationary?
    May 2021
    No it doesn't seem to happen when I do a U turn either for some reason, for example I was in a roundabout driving it home yesterday and it lost all power, then when I turned the wheel again straight it regained and I drove off
    Sep 2011
    adelaide
    18 Post(s)
    Petrol or Diesel?
    If petrol, get it analyzes on an oscilloscope my bet it`s the coil.
    May 2021
    It's a petrol yeah, and what the hell is that😂what coil should I be checking
    80 Post(s)
    Take it back to your insurer. It is obviously unsafe to drive and you've paid for your insurance excess.
  8. #7
    May 2021
    Yeah I have before I'm fucken done dealing with them, they're gonna pay me the money to fix it
  9. #8
    Sep 2011
    adelaide
    18 Post(s)
    The ignition coil. My daughters 4x4 was doing the same thing only on RH turns. I tossed it on MY oscilloscope and bingo the coil was faulty. Possibly a loose wire internally and when cornering it moved and shorted out.
    Could be the condenser, points or an ignition wire. If there is a fault in the system the oscilloscope with show it up.
  10. #9
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Are you sure it is not still in 4WD High Range? That will load up the transmission during turns on hard surfaces and cause loss of power.
  11. #10
    May 2021
    Yeah I'll give it a look this arvo sounds like it could be the problem, how would I go about testing the coil, can I just stick a multi on it somewhere and what values should I be looking for
