Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Fuel Tank Breathers!!
    Advanced sussgq's Avatar
    Dec 2020
    Post
    Yep gotya cheers for that ! I think I traced it out ...
    I come across this...
    that would be the one mate, is that a gu? gq one is a bit bigger and black, i binned mine & replaced it with a little ryco Z14 fuel filter. $10.90 from supercheap and i’ll be it’ll do a better job keeping water out :thumpup:
  2. The Following 2 Users Say Thank You to sussgq For This Useful Post:
    MB (13th May 2021), rusty_nail (13th May 2021)
    472 Post(s)
    Please do be watchful Sussgq Mate!
    The yonnies (rocks) my Nitto MT’s can collect/hold & flick are incredible versus my other BFG KM’s
    Maybe a Coke Can aluminium double wrap skin for plastic protection
  5. #13
    Dec 2020
    will do mate, it’s got the plastic splash cover back over it that goes around the filler neck after i took these photos. cheers!
  6. The Following User Says Thank You to sussgq For This Useful Post:
    MB (13th May 2021)
  7. #14
    472 Post(s)
    Perfecto
  8. #15
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    I guy I know used to have an air compressor hooked up to his fuel tank.
    2008 CRD Auto Wagon
  9. #16
    Apr 2021
    Brazil
    So I found this.
    What I assume is the one way valve at the end of the pipe ?
    And then this plasticy doodah cap thing on the end of it.
    Hi @Hodge!
    My fuel tank (diesel) is missing that white plastic cup there. Can you tell me if there is any sort of valve or something relevant inside or if it is just an empty cup?
    Also, where it attaches to that black plastic thing on the steel venting/breathing tube, does it make a tight seal? I will probably have to make myself one of those out of any plastic container with a similar size, so I am wondering if it needs to be sealed, or valved or what.
    Thanks for any info mate!
  10. #17
    Apr 2021
    Brazil
    Quote Originally Posted by sussgq View Post
    Hi @sussgq!
    What is that black hose clamped to the white cup for?
  11. #18
    Dec 2020
    Hi @Hodge!
    hey bud, that little upside down cup is just an empty sleeve that attempts to create an air pocket if you were to be that deep in water. the top of it isn’t tightly sealed at all, i covered it in permatex 3bond and pushed it on tight and left it to dry. the one way valve is down the line on the side of the tank, mine was broken so i binned it and put that small ryco filter in place instead.
    the hose clamped onto it is just me trying to make the air pocket a little bit bigger, probably useless haha
  12. The Following User Says Thank You to sussgq For This Useful Post:
    BrazilianY60 (3rd June 2021)
  13. #19
    Apr 2021
    Brazil
    Thank you. I'll probably drill a hole in the top of a pill container and use it in place of the missing one here.
  14. #20
    Dec 2020
    i’d advise turfing the one way valve and putting a little fuel filter in the line, they’ll catch water too in the event you get that deep and the little cup does sweet f all
