Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 136
Thread: Honey Badger the Y60
  1. #111
    462 Post(s)
    Wow! Thats come up beautiful. So precise is the colour separation.
    BrazilianY60 (23rd December 2021)
    194 Post(s)
    Looks great, well done, certainly not something I would have a go at.
  6. #113
    Apr 2021
    Brazil
    Paint job back on track!
    Long time since we were able to tackle painting again. It has rained a lot since December, and the humidity in our garage/shed was very high, making it improper for painting. We had to wait for a couple of weeks of full sun/heat to be comfortable enough to bring out the paint gun again.
    All I can say is that the paint job is almost done! We were able to finally paint the front fenders and the front panel/front clip.
    To call it done we still need to paint the cowl piece, the fuel door and the side cladding thing. Well, at least for the body... bumpers and front grill will be painted separately, as they have a different color, different clear coat, etc.
    Here is a sample of the result. Low quality video though, as I had forwarded it from one mobile to another using WhatsApp and it has heavily compressed the video.
  7. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    MB (30th March 2022), mudnut (30th March 2022)
  8. #114
    194 Post(s)
    That colour combo is delicious!
  9. #115
    Nice job. Wish I had the patience to fix my old Trol up like that.
  10. #116
    Apr 2021
    Brazil
    Engine bay "cleanup"
    As I would not take the engine out just for an engine bay paint job, we decided to give it a good clean and spray some paint around it on a best-effort basis. Whatever came out of that, we would call it good and never talk about it.
    To start, the part right in front of the battery tray where the washer bottle stays was (still is) "fuglly". Bed liner was spray'd over that section to hide it (from whom? LOL).
    Anything over the firewall like brake lines, A/C lines, etc were removed. We popped the rubber grommet with the engine bay harness towards the cab and removed all harnesses from the engine bay into the cab. Whatever we were not able to move or remove, we tied to the engine with cords and then wrapped the engine in painting paper. It was looking like a patient ready for surgery.
    After some spray, this was the result:
    We also have painted the top grill, hood/bonnet hinges and the jack housing. No pictures of them after the paint, but I believe we're done with blue paint.
  11. The Following 7 Users Say Thank You to BrazilianY60 For This Useful Post:
    Cremulator (12th April 2022), MB (12th April 2022), mudnut (12th April 2022), PeeBee (12th April 2022), Rossco (12th April 2022), rusty_nail (12th April 2022), Touses (12th April 2022)
  12. #117
    Apr 2021
    Brazil
    Cornering lights update
    Cornering lights update:
    Gave the front end lights a good wash. Notice here one of the corner lights missing some part.
    Attachment 84233
    For the cornering lights, the only thing I was able to do so far was to make up for the missing part with resin. Not that good, I must admit, but I left extra material to be sanded once the car is painted and then will paint the surroudings with a similar gray color. I hope that it looks a bit better after that of if I can hopefully be able to find new ones for an affordable price.
    Attachment 84241
    Attachment 84242
    I was finally able to source from China these aftermarket cornering lights at an affordable price. Definitely not OEM quality but hey, mine were epoxied/resin to shape by hand...
    Paraphrasing MB, "happy as a rat with gold tooth"!
  13. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    Cremulator (24th May 2022), MB (26th May 2022)
  14. #118
    Apr 2021
    Brazil
    Bumper restoration
    Bumpers were pretty damaged and twisted:
    I even hammered it myself a bit after the engine was rebuilt to be able to drive around without it touching the body and making a lot of noise. But then, it was time to proper address the situation. Since it was chrome plated, hammering it back to shape would leave hammer marks, so I decided to go for dark gray bumpers as some OEM models had. First step was to de-plate the chrome. The interesting part is that to chrome plate a steel part, you first copper plate it, then nickel plate it and only then chrome plate it. So after the de-plating process, it was left down to copper plating.
    A stretching jig was used to stretch it while it was being hammered, for the steel to find its place with the tension. It stretched quite ok. Then, the square holes for the carriage bolts that were rounded, were filled and later filed back to square.
    Test fitting:
    Filling, sanding, priming:
    Dark gray paint with satin clear coat:
    Final result:
    I am still working on those big bumperettes or whatever it is called. I am going to have to drill the tapped holes through the rubber and use carriage bolts. Also, they are cracked, so I am planning to fill the cracks with black windshield glue and try to cut the excesses with a utility knife or something.
  15. The Following 6 Users Say Thank You to BrazilianY60 For This Useful Post:
    Cremulator (2nd August 2022), MB (2nd August 2022), MB TD42 (12th November 2022), PeeBee (2nd August 2022), Rossco (6th November 2022), Touses (2nd August 2022)
  16. #119
    Apr 2021
    Brazil
    The end of the body work!
    Last Saturday, after exactly two years of bodywork and paint (approximately 90 days of work total), my Patrol came back!
    This is a personal milestone in this restoration and I am very happy that this day finally arrived.
    I have to reinstall the pedals, the boosters and the radiator to be able to take it for a drive around the block.
    Then it will be time for sound deadening, roof lining, windshield and other windows installation.
    Then it will be time for upholstering.
  17. The Following 4 Users Say Thank You to BrazilianY60 For This Useful Post:
    Bigcol (12th June 2023), Cremulator (2nd August 2022), MB (2nd August 2022), Touses (2nd August 2022)
  18. #120
    Apr 2021
    Brazil
    Today I have personally met one of the eight Patrol owners in the country. He has a donor car as well and he gave me a super nice gift!
    LHD passenger side (Aussie driver) front flare.
    I only had 3 of them and now I finally have the full set! Those will be restored and painted matte black.
    It's like finding that last piece of a 3000 pieces puzzle!
    Enviado de meu SM-G990E usando o Tapatalk
  19. The Following 8 Users Say Thank You to BrazilianY60 For This Useful Post:
    Cremulator (6th November 2022), MB (6th November 2022), MB TD42 (19th July 2023), mudnut (6th November 2022), pearcey (6th November 2022), Rossco (6th November 2022), rusty_nail (6th November 2022), Touses (12th June 2023)
