Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: fully welded radiator recommendations?
    461 Post(s)
    G’day PF Mate!
    Never underestimate an OEM Nissan placcy radiator Brother, from my personal experiences they are truly excellent but expensive every 2-3 decades
    FWIW: I have had custom local brass/copper specialty GU/Chev radiators made before.....huge $$$$$$ ....purely for the reasons of ease of self nuffy soldiering out there in the bush if needed after aluminium customs have failed on welds through Nullabor vibrations.
    Placcy OEM gets my Vote
    Yep. In my TD i've gone full ally, full copper/brass 3 core jobbies and have gone back to OEM.
    I brought an eBay radiator, the guys at Outback 4WD had to
    have the top and bottom removed floshed and re fitted.
    It would of failed other wise.
  4. #13
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    So the core and tanks were still good? What would have caused it to fail and in what way?
    John
  5. #14
    174 Post(s)
    G’day PF Mate!
    The one in my '06 is still going strong, but I guess that's what they do until they stop doing it! What's a new 'placcy' top one worth?
  6. #15
    472 Post(s)
    Around $600ish from Patrolapart IIRC Cuppa Mate!
  7. The Following User Says Thank You to MB For This Useful Post:
    Cuppa (4th May 2021)
  8. #16
    Patrol Guru paulyg's Avatar
    Ballarat
    My factory original radiator, top tank split,a couple of days ago, 140km from Longreach, had to make a temporary repair, then drive very carefully to Longreach, still waiting for an other radiator to arrive, the original core still looks new, but the plastic tanks get brittle with age, I don’t now how long they should last, but you could treat them as a service item and replace them at regular intervals.
  9. The Following User Says Thank You to paulyg For This Useful Post:
    MB (7th May 2021)
  10. #17
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    In my last vehicle (mazda b2500) the top tank in the oem radiator gave way at around 300,000kms so I'd naturally be cautious when approaching the big 300 mark.
    2008 CRD Auto Wagon
  11. The Following User Says Thank You to pollenface For This Useful Post:
    MB (7th May 2021)
  12. #18
    Morayfield, QLD
    When I converted to TD42T in 2015, the TB45E original plastic tank radiator was 14 years old but only 136k kms. I sold it on Gumtree for $100..
    A lot of ZD owners had issues with snapping off the small overflow/breather pipe when leaning into the engine bay.
    John
  13. The Following User Says Thank You to jff45 For This Useful Post:
    MB (7th May 2021)
  14. #19
    472 Post(s)
    FWIW: I now carry this small 2 part concoction found on Youtubey only a little while ago:
    Have a Youtubey search yourselves at how reactive the two are together with an incredible bond especially on plastics.
    Language warning: Aussie’s call the white powdery stuff ‘Bi-Carb Soda’ whereas Yank’s call it ‘Baking Soda’
  15. #20
    Nov 2019
    Perth
    5 Post(s)
    scientists call it sodium-bicarbonate
    2008 CRD Auto Wagon
  16. The Following User Says Thank You to pollenface For This Useful Post:
    MB (11th May 2021)
