Results 11 to 20 of 25
Thread: Front tube bar
    472 Post(s)
    Was typing same time John Mate!
    I assume they’ll be 40NB (48.3mm OD / 3.25mm ) which is fine
    jay see (27th April 2021)
    472 Post(s)
    Hold the Fort, are they requiring welding plates to the chassis John Mate?
  6. #13
    49 Post(s)
    Taken from their website.
  7. #14
    472 Post(s)
    Due Diligence required here Johnstar
    Competition bred sliders are traditionally designed with a chassis welded tapped plate that accepts the sliders matching bolt plate for ease of throw away after the race/challenge.
    On our daily vehicles this chassis welding requires full engineering certificates
    Here’s hoping you’ve been advised by the seller and or it’s a new lateral/sideways U bolt type design
    jay see (26th April 2021)
  9. #15
    49 Post(s)
    Cheers MB. Will dig a little deeper.
  10. The Following User Says Thank You to jay see For This Useful Post:
    MB (26th April 2021)
  11. #16
    201 Post(s)
    Can't go wrong with Millweld.
    https://www.millweld.com/a/GU-Winch-Bars
    I personally can't recommend Raslarr after the experience I had with them 6 or 7 years ago, maybe they have changed but I had a few issues with the workmanship and they were not interested in making it right.
  12. The Following User Says Thank You to Winnie For This Useful Post:
  13. #17
    40NB (40mm nominal bore) with a 3.25mm wall will be 46.5mm OD ��. Nominal Bore tube will normal have a schedule rating and this is what determines the wall thickness.
    So if you want a 50ish mm OD you will need to use 40nb with a 5.2mm wall thickness.
  14. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    jay see (27th April 2021), MB (27th April 2021)
  15. #18
    Also check if their bars are adr approved. Airbag compliant etc etc. These details are what insurers will be looking at if you were to run into someone or something. No compliance no insurance.
    The only way to get this compliance is to have the bar tested for impact and destruction.
  16. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
  17. #19
    472 Post(s)
    The 40Nb pipe we purchase is always 48.3mm OD with varying wall thicknesses, is this just a galvanised thingy, black maybe different?
    https://www.orrconsteel.com.au/sites...e-brochure.pdf
  18. The Following User Says Thank You to MB For This Useful Post:
  19. #20
    No you are right I was confused. It gets a little hazy sometimes. I deal with tube and pipe at work and they are measured differently. I was right about the schedule rating though.
    So yes your 40NB has an 0D of 48.3mm and a wall thickness at 3.2mm makes it schedule 30. Now if you go to the right place you can get other schedules as well.
    So Schedule 80 is 5.08mm wall thickness. Schedule 160 is 7.14mm wall thickness.
    For what it's worth we made a set of sliders for a new dmax at work and used 40DN (or NB) schedule 80 (5.08mm wall).
    Sorry about the above confusion...
  20. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
