Results 1 to 5 of 5
Thread: No ignition or dash power
    Dec 2017
    Good morning all. 97 GQ TD42 , went to start it this morning and nothing except was sounds like glow plug relay . Battery 13.1 v and terminals tight and clean. With ignition on I have power to accessories and ignition fuses . Fusible link ok and swapped over heaterfan relay with ignition relay. Any other possibilities
    Thanks in advance 😊
    I would check your earth lead. Remove and refit terminals.
    Dec 2017
    Got 12v to ignition starter relay beside battery (plug) but not to white or black/yellow wires that connect to relay. Ignition fuse (green) is ✅
    Dec 2017
    Up-date, alternator fuse blown. Wire had broken off capacitor and earthed. All running again
  6. The Following 4 Users Say Thank You to Patricapatrol For This Useful Post:
    MB (27th April 2021), mudnut (27th April 2021), PeeBee (27th April 2021), rusty_nail (27th April 2021)
    Jan 2018
    Pt Augusta SA
    Thanks for the update. Gives others another option.
