Results 1 to 4 of 4
Thread: GQ Auto
    Aug 2019
    GQ Auto
    Hi All,
    I have recently purchased a nice condition GQ Safari. If I select Drive in the auto box, the car wants to move off in a high gear. When I manually change the gears all is ok and when warmed up the problem with drive goes away but returns the next day. Has anyone got any suggestions as to where i should start looking for a fix for this.
    Lance
    Patrol Freak jff45's Avatar
    May 2012
    Morayfield, QLD
    13 Post(s)
    If the box has gone into “limp” mode, it starts in 3rd because the A & B shift solenoids get deactivated. There should be a procedure (I’m not familiar with GQs) to read the fault codes which should give you an idea where to start looking.
    John
    Aug 2019
    Thanks for the info, I will give that a go. Cheers Lance
    May 2023
    hi all new to forum i have gq tb42 patrol auto that intermittently drops out of gear and free revs
    if i put in nuetral and back in to drive it goes back to normal
    any ideas please
    cheers buzz
  6. The Following User Says Thank You to BUZZ510 For This Useful Post:
    MB (24th May 2023)
