Hey all,
sorry to create a new post, didnt seem right piggy back on the end of the others as they were a bit old.
I have a 2012 Y61 ST ZD30 Manual, with the factory rear locker.
Over the last few weeks, i have been getting a flickering of the DIFF LOCK LED on the dash, but it generally goes away.
It has lit up solid only once before (other than when i am actually using the DL), but now i have 4 LEDs lit up and the locker is actually engaged.
Doesn't matter what the transfer case is in, or where the locker switch is, the DL is engaged. You can hear it when turning (i am not driving it, this was troubleshooting).
Today i was in 2H and Diff Lock OFF - yet it was still engaged. i parked the car again, and started to troubleshoot.
So, i have searched the posts, and it seems that generally the solenoid is the problem. My symptoms seem a little different, so i wanted to see if anyone had some ideas.
If i remove both vacuum lines that run to the diff, i get vacuum constantly from a single port on the solenoid - regardless of switch position. no vacuum is on the other port, ever.
Testing the wires in the plug seem to indicate that the switch is working, as the voltage is seen on one wire when switched one way, and then seen on the other wire when switched the other way.
If i remove both vacuum lines at the same time, could this cause the strange behavior? i can see from looking at the unit that there are 2 unique solenoids within the assembly that are switched via the wiring loom.
apart from the input line, there is nothing in common with them that i can see.
Could i have 2 stuck solenoids - 1 stuck open and 1 stuck closed? can i blast them with an air compressor to try and unstick them?
Ive been looking into the MAC solenoids, but i really just need to get back on the road as its my only form of transport. any ideas?
Tim
