13th April 2021, 07:09 PM
larger tyres
Hi guys,poopsie here,just got my 2016 patrol back with its new ls3 and marks adapters kit.Absolutly great conversion,goes awsome and sounds great.I want to put 285/70/17 all terrain tyres on it but how can you fit the spare tyre on the standard tyre holder on rear door,thanks guys.
13th April 2021 07:09 PM
13th April 2021, 08:59 PM
There is a spacer you need to get mate quite easy to find. also keep an eye on the rear door with bigger spare they flex and over time crack but its a relatively simple fix for an engineer or panel beater. Ls3 patrol sounds amazing!!
The Following User Says Thank You to wagu89 For This Useful Post:
14th April 2021, 07:57 PM
Thanks for your reply,really can not see any positives for putting a better diesel in a patrol.The new crate ls3 has 425 hp and cost 11,ooo dollars and parts are cheap,no turbo,no egr,no dpf,no expensive fuel pumps etc.Can you put a smaller tyre on one axle if you get a flat[eg,265/70/17] when other tyres are 285/70/17 without damaging anything.Patrol does not have lsd but has difflock.,thanks a lot for replys.
15th April 2021, 10:44 AM
The factory rear lsd in my gu works bloody well!!!! Have to be real careful in the wet or gravel. Sounds like alot of fun mate can get a pic of that bracket if you need it
21st April 2021, 08:06 AM
If you want to go all large on your Nissan Patrol, then these Dick Cepek tires might be right up your alley. Not only are they high-quality, but they're very affordable as well.
